  • Joost Klein 10 posts 40 karma points
    Nov 10, 2014 @ 10:45
    Joost Klein
    Mysterious green bullet at nodes
    Sometimes the nodes in Umbraco 7 show green bullets. I can't figure out why they are there. Does anyone know what they are trying to tell me?
    Nov 10, 2014 @ 10:47
    Hi Joost
    That's really weird :)
    What exact version of Umbraco 7 are you running?
    Nov 10, 2014 @ 10:48
    Joost Klein
    Umbraco version 7.1.7 assembly: 1.0.5388.28062
    Nov 10, 2014 @ 10:55
    Dennis Aaen
    Hi Josst,
    The green symbol, is to tell you that the page is saved but not published yet, so the changes would not be visible on the frontend until you hit the save and publish button, for the  links page.
    Hope this helps,
    /Dennis
    Nov 10, 2014 @ 10:56
    Ah yes, of course it is! :) #H5IS.
    Nov 10, 2014 @ 10:57
    Joost Klein
    Ok weird, because i always use [save and publish] after making chnages. It happens on al 90 Umbraco sites we have delivered.
    Nov 10, 2014 @ 11:05
    Hi Joost
    Ok, so does the "Links" page from your screendump contain the latest changes you have made to it when you see it on your public facing website?
    Nov 10, 2014 @ 11:09
    Joost Klein
    Yes, it does:
    Backend
    Front
    Node
  • Stefan Kip 1614 posts 4131 karma points c-trib
    Nov 10, 2014 @ 11:12
    Stefan Kip
    It could be because of a 'ApplicationEventHandler' class, which subscribes to the ContentService.Saving event and saves the content, without publishing it?
    E.g. third party plug-ins or custom code can cause this.
  • Richard Soeteman 4049 posts 12922 karma points MVP 2x
    Nov 10, 2014 @ 14:08
    Richard Soeteman
    101
    It's your customer using the preview button see issue http://issues.umbraco.org/issue/U4-5510 should be fixed in 7.2
    Hope this helps,
    Richard
