  • cbicer 1 post 21 karma points
    Nov 14, 2014 @ 11:01
    cbicer
    New Command Problem
    Hi, I'm using Umbraco v6.0.5 and I have a problem. What should I do to create a new command on the website? Am I able to do this without writing code? I think it needs to be done with the code. I'm just creating content by using Umbraco. Can I solve this myself? Because the software developer is not interested in our website. Our website isn't live so I can't give you the URL.
    Thanks for your help.
    Nov 14, 2014 @ 11:06
    Hi cbicer and welcome to our :)
    If you need to add functionality to the website and you don't know how to code yourself then you need to get in touch with your website developer or find another certified developer who can help you out.
    You can find a list of certified developers here http://umbraco.com/certified-partners/find-a-certified-developer by clicking on the links for certified developers level 1 or level 2.
    You can also find solution providers here http://umbraco.com/certified-partners/browse-solution-providers
    Hope this helps.
