  • Carlos Mosqueda 244 posts 435 karma points
    Nov 17, 2014 @ 20:54
    Carlos Mosqueda
    Umbraco 7, build navigation from MultiNode Tree Picker?
    How do use the MultiNode Tree Picker in Umbraco 7 to build a navigation. I am trying to use a PartialView. We used to do a MacroScript but wanted to try my hand at the MVC and Partial views.
    My code is below but it just keeps not rendering.  I have the MultiNode Tree picker set up on a Node as a property but I keep getting a customError page via MVC.  I don't quite understand where it is breaking. I even try to just print out the name of my var 'mainNavi' (below) and that gives me nothing.  Any ideas?
    My current code is:
    var mainNavi = Umbraco.Content(1544);
    <div id="mainNavTop">
    <nav class="left">
    <ul id="mainNav">
    @foreach (var x in @mainNavi.mainNavigationPicker)
    var page = Umbraco.Content(x.InnerText);
    var firstSubLevel = page.Children.Where("template!=0").Where("Visible");
    var selected = Array.IndexOf(CurrentPage.Path.Split(','), page.Id.ToString()) >= 0 ? " class=\"selected\"" : "";
    <li>@page.Name
            @if (firstSubLevel.Count() > 0)
                <ul class="subNavFirst">
                @foreach (var secondPage in firstSubLevel)
                var subSelect = Array.IndexOf(Model.Path.Split(','), secondPage.Id.ToString()) >= 0 ? " class=\"selected\"" : "";
                <[email protected](subSelect)>@NavLevel(@secondPage)</li>
                </ul>
    </li>
    </ul>
    </nav>
    <!-- END MAIN NAV -->
    @*HELPERS*@
    @helper NavLevel(dynamic page)
       if(page.NodeTypeAlias == "Redirect")
          if (page.HasValue("alternateNavigationName"))
              if(page.openInNewWindow){
                <a href="@page.redirectURL" target="_blank">@page.alternateNavigationName</a>
              }else{
                 <a href="@page.redirectURL">@page.alternateNavigationName</a>
          else
                <a href="@page.redirectURL" target="_blank">@page.Name</a>
              }else{
                 <a href="@page.redirectURL">@page.Name</a>
       else
            <a href="@page.Url">@page.alternateNavigationName</a>
           else
             <a href="@page.Url">@page.Name</a>
  • Steve Morgan 1349 posts 4459 karma points c-trib
    Nov 18, 2014 @ 09:50
    Nov 18, 2014 @ 17:37
    Carlos Mosqueda
    @Steve,
    You would be correct in your thinking. I just had to clean up some code and I was going to post my code here.  But your find lead me to the right direction.
    My solution for our implementation.
    @*Top level navigation new structure*@
    var naviList = Umbraco.Content(1544).mainNavigationPicker.ToString().Split(new string[] { "," }, StringSplitOptions.RemoveEmptyEntries);
    var naviCollection = Umbraco.Content(naviList);
    <nav class="left">
    <ul id="mainNav">
        @foreach (var item in naviCollection)
            var firstSubLevel = @item.Children.Where("Visible");
            <li class="@(item.IsAncestorOrSelf(CurrentPage) ? "selected" : null)">
                @NavLevel(@item)
                               <li class="@(secondPage.IsAncestorOrSelf(CurrentPage) ? "subSelected" : null)">
                                   </li>
                            </ul>
            </li>
    </ul>
    </nav>
    @*HELPERS*@
    @helper NavLevel(dynamic item)
       if(item.NodeTypeAlias == "Redirect")
          if (item.HasValue("alternateNavigationName"))
              if(item.openInNewWindow){
                <a href="@item.redirectURL" target="_blank">@item.alternateNavigationName</a>
              }else{
                 <a href="@item.redirectURL">@item.alternateNavigationName</a>
          else
                <a href="@item.redirectURL" target="_blank">@item.Name</a>
              }else{
                 <a href="@item.redirectURL">@item.Name</a>
       else
            <a href="@item.Url">@item.alternateNavigationName</a>
           else
             <a href="@item.Url">@item.Name</a>
