umbracoDefaultUILanguage does not change anything for me
Hi Guys,
Today I updated and downloaded the language files for Polish, named it "pl.xml" and placed it in the umbraco/config/lang folder the place where other language versions reside. Unfortunately my successes end here :) Changing the prefered language in the browser settings is only as effective as showing right messages on the http://localhost/umbraco/login.aspx - but now even if I change the preferred language back to en or any other the login screen still shows up in Polish. The Umbraco UI stays in english no matter what I do - change the preferred browse language, set the umbracoDefaultUILanguage to "pl" in the web.config file, removing other language files and leaving only Polish (results in showing a little bit of Danish - or so I think - and [something] in most cases).
Ok - stupid question of a newbie.. I had to change the culture of the user (admin in my case). Unfortunately the culture doesn't affect the section icons but all the rest works fine.
Hi Guys,
Has anybody ever had this problem?
Best regards,
Max
