  • Tommy 5 posts 25 karma points
    Dec 14, 2009 @ 07:01
    Tommy
    Is there any way to export (or package) media & folders
    For media, is there any way to export the files (with folders) for importing? I was hoping the developer>packages would have it, but no.
    Am I missing something fundamentally?
    Dec 14, 2009 @ 08:50
    Dirk De Grave
    Hi Tommy,
    Media is currently not supported for import/export through packages. You'll have to build small app to sync across multiple installations.
    /Dirk
  • Janusz Stabik 15 posts 35 karma points
    Aug 04, 2010 @ 17:02
    Janusz Stabik
    Is this still the case (i.e. can media still not be exported using packages)?
  • Sascha Wolter 615 posts 1101 karma points
    Aug 04, 2010 @ 17:21
    Sascha Wolter
    Hi Janusz,
    that's unfortunately still the case with v4.5.1. You can add the underlying media files one by one but you can't include Media items.
    Sascha
