For media, is there any way to export the files (with folders) for importing? I was hoping the developer>packages would have it, but no.
Am I missing something fundamentally?
Hi Tommy,
Media is currently not supported for import/export through packages. You'll have to build small app to sync across multiple installations.
/Dirk
Is this still the case (i.e. can media still not be exported using packages)?
Hi Janusz,
that's unfortunately still the case with v4.5.1. You can add the underlying media files one by one but you can't include Media items.
Sascha
Upload image
Is there any way to export (or package) media & folders
Hi Tommy,
/Dirk
Hi Janusz,
Sascha
