  • Emil Christiansen 66 posts 148 karma points
    Nov 27, 2014 @ 12:00
    Emil Christiansen
    Error on deleting node in Umbraco 6.2.4 after upgrade
    Hi!
    I am getting this error on deleting a published or unpublished node through the backoffice:
    Error handling action Unable to cast object of type Umbraco.Core.Events.MoveEventInfo`1[Umbraco.Core.Models.IContent]' to type 'Umbraco.Core.Models.IContent'.
    The node is deleted, but the content-tree collapses and the error message is of course not a good user experince.
    We have upgraded the site from a v. 4.11.10 to 6.2.4. - everything else seems to work fine.
    Thanks in advance!
    /Emil
    Nov 27, 2014 @ 12:05
    Hi Emil
    Does it happen on each pagetype you're trying to delete or only on specific ones?
    Do you have a pagetype, which does not contain any datepickers for instance? What if you create a new document type, which is empty and allow it to be created beneath your root node and then try to delete it. Does that go as intended or does the error still appear in that scenario?
    Nov 27, 2014 @ 12:52
    Emil Christiansen
    Hi Jaaaaaaaaaaan :)
    Yes, it happens on all pagetypes - also on pagetypes without datepickers.
    I have created a new empty documenttype - and then created a node beneath the root as you said. Sadly it throws the same error.
    /Emil
    Nov 27, 2014 @ 13:06
    Hi Emiiiiiiiiiiiiiiiil!
    Hmm, I don't suppose that the /app_data/logs file reveal anymore information that what you have already posted above?
    Dec 02, 2014 @ 10:12
    Emil Christiansen
    Hi Jaaaaaaan...
    No, unfortunately there is nothing regarding the error. I am getting this in the file logs after i have created and deleted a new node:
    2014-12-02 10:08:10,287 [28] INFO umbraco.cms.businesslogic.web.Document - [Thread 20] New document 13497 2014-12-02 10:08:31,050 [28] INFO Umbraco.Core.Publishing.PublishingStrategy - [Thread 19] Content 'Test' with Id '13497' has been unpublished. 2014-12-02 10:08:31,973 [28] WARN Umbraco.Web.Routing.DefaultUrlProvider - [Thread 19] Couldn't find any page with nodeId=13497. This is most likely caused by the page not being published.
    In the database i am seeing this:
    302597 0 13497 2014-12-02 10:08:32.210 UnPublish UnPublish performed by user 302596 0 13497 2014-12-02 10:08:20.037 Open
    302595 0 13497 2014-12-02 10:08:11.923 Save Save Content performed by user 302594 0 13497 2014-12-02 10:08:10.280 New Content 'Test' was created with Id 13497
    Does anybody have any idea what's wrong?
    Dec 04, 2014 @ 10:23
    Hi Emiiiiiiiiiil
    Have you checked that the UI.xml file is correct? Perhaps it's missing some entries for some reason? Something that has perhaps not been merged in or whatever?
    Dec 08, 2014 @ 08:11
    Emil Christiansen
    Hi Jaaaaan
    Found a solution on this.
    Apparently there was a custom-eventhandler which had a problem :(
    Thanks!
    /Emil
    Dec 08, 2014 @ 08:23
    Hi Emiiiiil
    Ok, cool that you managed to get it fixed - Always those darn customized things that breaks all the stuff :)
    Greet them guys'n'gals, mkay?
