  • Tye Odle 3 posts 23 karma points
    Dec 16, 2009 @ 23:04
    Tye Odle
    UI doesn't completely load in IE 8 or Firefox 3.5 and other querky things
    When I first open the Umbraco UI in Firefox 3.5 it shows the loading bar but says done on the bottom left with no tree or anything showing. In IE 8 it shows the tree but doesn't completely load the Welcome Administrator section all the way. I have to hit refresh to get everything. Then...for example when I hit settings the first time it doesn't load the settings tree; I have to hit settings again for the tree to load. It does it whenever I hit content, settings, developer or whatever.
    I am getting used to it but I'm not sure a client will appreciate it.
    Is anyone else experienced this?
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    Dec 16, 2009 @ 23:06
    Douglas Robar
    Very strange. I would guess you've got a file-permission problem somewhere.
    Do you get any javascript errors? Or, if you use firebug, do you see any files that are not loaded properly?
    cheers,
    doug.
    Dec 17, 2009 @ 03:38
    Tye Odle
    Interesting; I pushed the test site up to a production ISP and it the problems stopped even though I am still viewing and using the same browsers so... the only other thing I can think of is that it may have something to do with the Cassini server which I am using on my workstation - who knows - so I will leave it at that.
    Thanks for the help.
