Been running for a while but just setting up in a new environemnt. This was just a straight db copy from our prelive environment back to dev. After enquiring here there is in fact a possibitly that files in prelive could have changed from what we have in dev - ie Courier could have been installed apparently. I'll get the chance to do a file compare on Monday.
Macro-parameter-save fails and leaves blank area - no error
Hi all
Umbraco V 4.11.8
When I try to save a macro parameter, the following happens but no error in Umbraco log and no ysod... and no parameter is saved.
Before:
After:
Can anybody help?
J
Hi Jules
Do you get any error messages in your browser console log?
Is this happening on a clean installation or has it been running for a while? In which environment does it happen?
In fact I do
I get these:
Hi Jules
Ok, is it a clean installation or an installation that has been running for a while?
Did you make any changes before you tried to add the parameter? Like installing a package or something?
Thanks for your help so far.
J :)
