  • Simon 692 posts 1068 karma points
    Dec 17, 2014 @ 09:46
    Simon
    Querying Relations in Razor View
    I am new to Umbraco, and appreciate any help. I am using nuPickers for relating a school class with student document types. I have achived that where a class has a number of students.
    But now, in the class template, I would like to know to query relations so that in the school class template I will be able to display all students of that class.
    I am using Umbraco 7+
    Appreciate any help.
    thanks
    Simon
    Dec 17, 2014 @ 09:57
    Dave Woestenborghs
    Have a look at the GetRelations method of uQuery : http://our.umbraco.org/documentation/Reference/Querying/uQuery/Relations
    Dave
    Dec 17, 2014 @ 09:59
    Simon
    Instead of hard coded IDs, how can I get the page ID?
    Dec 17, 2014 @ 10:03
    Dave Woestenborghs
    @Model.Content.Id or @CurrentPage.Id
    Dec 17, 2014 @ 10:07
    Simon
    It is throwing an error that The name 'CurrentPage' does not exist in the current context
    Dec 17, 2014 @ 10:20
    Simon
    Ok Dave, I was not inherting from @inherits Umbraco.Web.Mvc.UmbracoTemplatePage
    Dec 17, 2014 @ 10:27
    Simon
    Hi Dave,
    What is the namespace/reference for Document, because I want to get Document By Id and use such properties?
    thank you.
    Dec 17, 2014 @ 12:04
    Dave Woestenborghs
    You can do @Umbraco.TypedContent(idofyournode).
    Dave
    Dec 17, 2014 @ 12:13
    Simon
    What is the difference betwen @Umbraco.TypedContent(1112) and @Umbraco.Content(1112)?
    simon
    Dec 17, 2014 @ 12:23
    Dave Woestenborghs
    TypedContent returns a strongly typed object of type IPublishedContent.
    Content returns a dynamic object.
    The same goes for @Model.Content and @CurrentPage
    Dec 17, 2014 @ 12:39
    Simon
    And what is the difference between strongly typed object and dynamic object  in Umbraco?
    Dec 17, 2014 @ 12:51
    Dave Woestenborghs
    With the strongly typed you have intellisense in visual studio.
    I will try to explain the difference for getting a property of your content called "visual".
    With the strongly typed object you will do :
    @Model.Content.GetPropertyValue("visual")
    With dynamic you will do
    @CurrentPage.Visual.
    The last one will try to call the first one under the hood and will fail if it can be found.
    Dave
