Can the default droplist datatype allow only one selection to be selected by one node at a time?
Example:
I have a droplist datatype with 5 options Option1 Option2 Option3 Opiton4 Option5
I have 3 nodes that allow this droplist datatype. Node 1 Node 2 Node 3
Is it possible that if Node 1 has Option2 selected that the other nodes will not be able to select Option2 from the droplist unless Node 1 resets it's droplist to non selected.
Droplist datatype, can option only be selected once per node?
Example:
Option1
Option2
Option3
Opiton4
Option5
Node 1
Node 2
Node 3
Does that make sense?
