This is the first time I've tried the "Remove at" property under "Properties" but as far as I can see nothing happens when I set a date and a time for a certain page? The page in question is still published after the "Remove at" date and time has passed. I haven't tried this using whole days though, I just set the remove at date fifteen minutes into the future.
The web server is on the same timezone as my desktop computer where I do the settings and I've checked that we have the same time settings (give or take a few seconds).
What happens is that when umbraco starts, it sets up a timer. That timer runs every minute, but the first run happens 10 minutes after umbraco has started. So if you are on a laptop, your application pool might not live for 10 minutes, causing the (un)publishing service to never run.
For testing I changed to timers in the source, and compiled my own version to start running the publishingservice right after the app has started.
Look into a ping service that pings your site say every 9 minutes or so, because I think I remember someone saying if the site is idle for 10 or 11 minutes IIS does something to save resources and I think this screws things up with the timer?? Need someone to back that up though as I may be wrong :S
Remove at - does it work and if so, how?
Hi!
Or is this the wrong way to use it?
Thanks!
/Thomas Kahn
I am using it, and it is working well here.
Hi Morten!
It should work for me then. The site is not on a laptop but a big Windows 2008 server and the site has been up and running for days. Strange...
/Thomas
Also, check the umbraco log table. There are some big try/catch blocks, but they should log any errors to the db.
