    Jan 15, 2015 @ 17:26
    Ismail Mayat
    insert link url from rte
    We got an old 4.7.1 site and its multilingual however setup as
    Content
      en
      cn
      fr
    etc etc, when you insert links in a country section the url does not contain the language prefix e.g. /en/whatever you get /whatever so is it possible to update that url i guess write an http handler or fudge with some javascript?
    Regards
    Ismail
    Jan 15, 2015 @ 20:14
    Hi Ismail
    Has useDomainPrefix been set to true in the /config/UmbracoSettings.config file? If so I think that is perhaps the reason why?
    Jan 16, 2015 @ 09:35
    Ismail Mayat
    Jan,
    Just set it to true no joy, thing is this site was not designed by us and on the root nodes no domain is set the driver for language instance is www.whater.com/en /fr etc etc the host is only set in iis.  Anyhow i have written some jquery to do it, I know that rte is contained within a div with specific class so i can target it and just update internal links in that area, also as we have a global language switcher i know which language they are in, not ideal but it works.
    Regards
    Ismail
