A multi-step Contour form breaks when hitting 'previous'
1. Created a multi-step contour form in one pass and applied it to a page using richtext editor and published the page (http://www.logotukku.fi/tilaa.aspx)
2. When testing the form, filled the first step fields and clicked "next". Filled the second step fields and clicked 'previous'.
The page fails with following error message: 'Input string was not in a correct format.'
[FormatException: Input string was not in a correct format.] System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) +7469351 System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) +119 System.String.System.IConvertible.ToInt32(IFormatProvider provider) +46 System.Convert.ToInt32(Object value) +28 umbraco.providers.members.UmbracoMembershipProvider.GetUser(Object providerUserKey, Boolean userIsOnline) in d:\TeamCity\buildAgent\work\7380c184e9fcd3ea\umbraco\providers\members\MembersMembershipProvider.cs:605 System.Web.Security.Membership.GetUser(Object providerUserKey, Boolean userIsOnline) +61 System.Web.Security.Membership.GetUser(Object providerUserKey) +6 Umbraco.Forms.Core.Record.ToXml(XmlDocument xd) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Core\Record.cs:51 Umbraco.Forms.Data.Storage.RecordStorage.UpdateRecordXml(Record record, Form form) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Core\Data\RecordStorage\RecordStorage.cs:208 Umbraco.Forms.Data.Storage.RecordStorage.UpdateRecord(Record record, Form form) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Core\Data\RecordStorage\RecordStorage.cs:185 Umbraco.Forms.Core.Services.RecordService.SaveRecord() in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.Core\Services\RecordService\RecordService.cs:328 Umbraco.Forms.UI.Usercontrols.RenderForm.prevPage(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\39da791f9304089a\Umbraco.Forms.UI\Usercontrols\RenderForm.ascx.cs:193 System.Web.UI.WebControls.Button.OnClick(EventArgs e) +111 System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +110 System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10 System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13 System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
4. Deleted and rebuild the form and the page, with same results.
Background information: Windows 2003 Server with SQL Server 2005. Umbraco 4.0.3 with Contour license.
Comment author was deleted
Hi Markku,
It looks like you are running an older version. This issue has been resolved. To update you'll have to download the update zip from here:
http://nightly.umbraco.org/Umbraco%20Contour/1.0.7/
And then just copy the new files over the existing ones.
