Umbraco suddently crashed after scheduled publish.
I have an umbraco 4.02 install on my Windows Vista PC.
Today i have experimented with the "publish at" propeerty for a page for the first time.
I set a page to publis at today at 12.00. As soon as the clock was after 12 Umbraco crashed and now i get a server error when ever i click a page in the content tree.
I can start Umbraco and login, and everything seems normal, but if i click any page in the content tree i get this server error (YSOD):
Object reference not set to an instance of an object. Beskrivelse: Der opstod en undtagelse, der ikke blev behandlet, under udførelse af den aktuelle webanmodning. Se staksporingen for at få yderligere oplysninger om fejlen, og hvor den kom fra i koden.
Detaljer om undtagelse: System.NullReferenceException: Object reference not set to an instance of an object.
Kildefejl:
Der blev oprettet en undtagelse, der ikke blev behandlet, under kørsel af den aktuelle webanmodning. Du kan finde oplysninger om undtagelsens oprindelse og placering ved hjælp af nedenstående staksporing af undtagelser.
Staksporing:
[NullReferenceException: Object reference not set to an instance of an object.] umbraco.controls.ContentControl.addControlNew(Property p, TabPage tp, String Caption) +54 umbraco.controls.ContentControl..ctor(Content c, publishModes CanPublish, String Id) +780 umbraco.cms.presentation.editContent.OnInit(EventArgs e) +367 System.Web.UI.Control.InitRecursive(Control namingContainer) +333 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +378
I've just experienced exactly the same issue with a scheduled publish (probably). Issue was fixed (but for how long?) with a restart of the AppPool on IIS.
Kildefejl:
Staksporing:
This happend at the same time the page was set to publish, but i'm not sure that there is a connection ???
What happend ?
What can i do to get my Umbraco install to work again.
Thanks, merry X and happy new year to all.
Mikael
Ok, so two reboots seems to have solved the problem, but my page was not published, and i still wonder what happend.
I have tried to set a new publish date/ time to check again.
Mikael
Hmm, the second attempt just worked as expected, so the crash was probably IIS related more than Umbraco related.
Mikael
