Version 4.0.3: I click on my content tab and nothing when I view the source there is a textarea control with an element style of visibility: hidden. The control was loading correctly yesterday and nothing has changed besides deleting some properties.
Any ideas I have replaced all the tinymce configs with the orig and still nothing... Could a server change have effected this?
Sorry to keep posting to my own thread... The issue has been resolved. I replaced the config files and umbraco/plugins folder and all seems to be working again. I assume something got corrupt somehow :( I would still appreciate any information someone can bring to this issue?
If I were to guess about the original cause I would suspect a file permission problem. This sometimes happens if the application pool owner changes, if FTP is used to upload files, if a user directly saves a file and the owner changes, etc. The end result is that the site's application pool owner might not have the needed rights to open a file or files. Permission issues give the strangest errors and the more peculiar the behavior the more I am inclined to think file permissions are at the heart of the issue.
URGENT! RTE Randomly stopped showing
In addition this is the exception from the server:
Event Type: Warning
Event Source: ASP.NET 2.0.50727.0
Event Category: Web Event
Event ID: 1309
Date: 12/29/2009
Time: 10:35:41 AM
User: N/A
Computer: **********
Description:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 12/29/2009 10:35:41 AM
Event time (UTC): 12/28/2009 11:35:41 PM
Event ID: 290794dc991a4e2ba7e24e7e9f1815c6
Event sequence: 69
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: ***********
Trust level: Full
Application Virtual Path: /
Application Path: ****************
Machine name: ************
Process information:
Process ID: **********
Process name: **********
Account name: **********
Exception information:
Exception type: HttpException
Exception message: The remote host closed the connection. The error code is 0x80072746.
Request information:
Request URL: http://www.***********.***/umbraco/plugins/tinymce3/tinymce3tinymceCompress.aspx?rnd=7cfc5933-3c1b-4b9c-822b-73f922fab5c9&module=gzipmodule&themes=umbraco&plugins=contextmenu,advimage,paste,media,advlink,umbracocss,umbracomacro,noneditable,inlinepopups,table&languages=en
Request path: /umbraco/plugins/tinymce3/tinymce3tinymceCompress.aspx
User host address: ****************
User:
Is authenticated: False
Authentication Type:
Thread account name: ***********
Thread information:
Thread ID: *
Thread account name: *****************
Is impersonating: False
Stack trace: at System.Web.Hosting.ISAPIWorkerRequestInProcForIIS6.FlushCore(Byte[] status, Byte[] header, Int32 keepConnected, Int32 totalBodySize, Int32 numBodyFragments, IntPtr[] bodyFragments, Int32[] bodyFragmentLengths, Int32 doneWithSession, Int32 finalStatus, Boolean& async)
at System.Web.Hosting.ISAPIWorkerRequest.FlushCachedResponse(Boolean isFinal)
at System.Web.HttpResponse.Flush(Boolean finalFlush)
at System.IO.Compression.DeflateStream.InternalWrite(Byte[] array, Int32 offset, Int32 count, Boolean isAsync)
at System.IO.Compression.DeflateStream.Write(Byte[] array, Int32 offset, Int32 count)
at System.IO.Compression.GZipStream.Write(Byte[] array, Int32 offset, Int32 count)
at umbraco.presentation.plugins.tinymce3.GzipCompressor.StreamFromTo(Stream in_stream, Stream out_stream, Int32 buff_size, CloseMode mode)
at umbraco.presentation.plugins.tinymce3.GzipCompressor.Compress(Stream to_stream)
at umbraco.presentation.plugins.tinymce3.GzipModule.ProcessRequest(HttpContext context)
at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Glad you got it sorted out!
cheers,
doug.
Thanks NightWolf, solved my prob aswell.
