I'm trying to move some functionallity from one site to another site using a package. There's a lot of different stuf in it. Some icons, XSLT file, data types, content nodes, document types, macros and templates.
But when I'm installing the package I get an error. The only problem that occours, is that my document types is not allowed under each other. I tried using the package action: Allow document type but I can't make it work.
Here is what i need. I have a document type called "ContentElementsFolder". Under this document types it shall be possible to create three different documenttypes called: "InfoboxFolder", "FeedboxFolder" and "CategoryFolder".
And under those three document types another document type should be allowed: Under "InfoboxFolder" a document type called "Infobox" shall be allowed. Under "FeedboxFolder", "Feedbox" shall be allowed and so on.
But how do I write this correctly in the package action.
By the way, alle of the templates, files, macros, document types and datatypes is installed correctly. The only thing that's missing is the content nodes because they are not allowed under each other.
Don't see a problem with your code, so bit puzzled as to why the code would not work? Can you check the umbracoLog table either directly in db or through the excellent Log Manager for some specific installation entries?
I installed the Log Manager package, and then tried to install my own package again. This is the error that I get in the Log:
At
/umbraco/developer/packages/installer.aspx?installing=businesslogic&dir=D:\Data\web\Umbraco\4.0.2.1\UmbracoPackage\data\c25c6a35-283c-4762-8416-3a028b69f74a&pId=7
(Referred by:
http://package.ws-ka/umbraco/developer/packages/installer.aspx):
System.NullReferenceException: Object reference not set to an instance
of an object. at
umbraco.cms.businesslogic.packager.Installer.InstallBusinessLogic(Int32
packageId, String tempDir) at
umbraco.presentation.developer.packages.Installer.processInstall(String
currentStep) at
umbraco.presentation.developer.packages.Installer.Page_Load(Object
sender, EventArgs e) at
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o,
Object t, EventArgs e) at
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender,
EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at
umbraco.BasePages.BasePage.OnLoad(EventArgs e) at
System.Web.UI.Control.LoadRecursive() at
System.Web.UI.Page.ProcessRequestMain(Boolean
includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
I just looked at my aliases once more, and copy/pasted them into the package action, but I still get the error:
At
/umbraco/developer/packages/installer.aspx?installing=businesslogic&dir=D:\Data\web\Umbraco\4.0.2.1\UmbracoPackage\data\fb956e14-69c6-4f3d-ba1a-0cb5733592ca&pId=7
(Referred by:
of an object. at
currentStep) at
In two of my aliases i have square brackets ([ ]). They actually looks like this:
(I also included the correct aliases for those two, just didn't write them in my first post in here because the aliases were on danish, but with no weird danish characters)
Or does it have something to do with spaces in the aliases? And just to be 100% clear. It's the document type alias I need to use right? Not the name or anything weird.
Yes, I've checked that in code, you need the alias of the doc type, that's for sure. I don't think those brackets could be the issue, but it wouldn't hurt to trial and error without, wouldn't it? Probably not what you'd want to hear, but best is to exclude all 'noise' to verify whether that could be the issue.
Problem with package action: Allow document type
I tried this:
<Action runat="install" alias="allowDocumenttype" documentTypeAlias="FeedboxFolder" parentDocumentTypeAlias="ContentElementsFolder" />
<Action runat="install" alias="allowDocumenttype" documentTypeAlias="InfoboxFolder" parentDocumentTypeAlias="ContentElementsFolder" />
<Action runat="install" alias="allowDocumenttype" documentTypeAlias="CategoryFolder" parentDocumentTypeAlias="ContentElementsFolder" />
<Action runat="install" alias="allowDocumenttype" documentTypeAlias="Category" parentDocumentTypeAlias="CategoryFolder" />
<Action runat="install" alias="allowDocumenttype" documentTypeAlias="Feedbox" parentDocumentTypeAlias="FeedboxFolder" />
<Action runat="install" alias="allowDocumenttype" documentTypeAlias="Infobox" parentDocumentTypeAlias="InfoboxFolder" />
But it doesn't work. Am I doing something wrong?
Anyone have a clue?
Kim,
/Dirk
At /umbraco/developer/packages/installer.aspx?installing=businesslogic&dir=D:\Data\web\Umbraco\4.0.2.1\UmbracoPackage\data\c25c6a35-283c-4762-8416-3a028b69f74a&pId=7 (Referred by: http://package.ws-ka/umbraco/developer/packages/installer.aspx): System.NullReferenceException: Object reference not set to an instance of an object. at umbraco.cms.businesslogic.packager.Installer.InstallBusinessLogic(Int32 packageId, String tempDir) at umbraco.presentation.developer.packages.Installer.processInstall(String currentStep) at umbraco.presentation.developer.packages.Installer.Page_Load(Object sender, EventArgs e) at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at umbraco.BasePages.BasePage.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Looks like there might be a typo in one of your alias names, have a look at the upper/lower-casing as well.
At /umbraco/developer/packages/installer.aspx?installing=businesslogic&dir=D:\Data\web\Umbraco\4.0.2.1\UmbracoPackage\data\fb956e14-69c6-4f3d-ba1a-0cb5733592ca&pId=7 (Referred by: http://package.ws-ka/umbraco/developer/packages/installer.aspx): System.NullReferenceException: Object reference not set to an instance of an object. at umbraco.cms.businesslogic.packager.Installer.InstallBusinessLogic(Int32 packageId, String tempDir) at umbraco.presentation.developer.packages.Installer.processInstall(String currentStep) at umbraco.presentation.developer.packages.Installer.Page_Load(Object sender, EventArgs e) at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at umbraco.BasePages.BasePage.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
<Action runat="install" alias="allowDocumenttype" documentTypeAlias="[K]Feedbox" parentDocumentTypeAlias="FeedboxFolder" />
<Action runat="install" alias="allowDocumenttype" documentTypeAlias="[K]Infobox" parentDocumentTypeAlias="InfoboxFolder" />
is that a problem?
Let us know what you find out.
/Dirk
I'll try it out in the new year. And report back on what I find out.
Happy new year to all of you so far :)
