  • lin04com 7 posts 27 karma points
    Dec 30, 2009 @ 11:53
    lin04com
    How to get a real path in Umbraco folder?
    Hello,everybody!
    I am a new Umbraco user, i downloaded the project and install sucessfully, now i get a trouble for real path in Umbraco's folder. Maybe it's a url rewrite issue,but i dont't know how to do it, can anyone help me?
    I clicked the link(http://localhost:84/contact-us/index.aspx),  there is a real directory,but i get an error when i clicked "contact-us/index.aspx".
    The issue like this:
    " No umbraco document matches the url 'http://localhost:84/contact-us/index.aspx'
    umbraco tried this to match it using this xpath query'/root/node/node [@urlName = "contact-us"]/node [@urlName = "index"] | /root/node [@urlName = "index"]')
    This page can be replaced with a custom 404 page by adding the id of the umbraco document to show as 404 page in the /config/umbracoSettings.config file. Just add the id to the '/settings/content/errors/error404' element. "
    Sorry,my english is very poor, can anyone know what i say?
    Can anyone tell me how to resolve it?
    Lin04com
  • Jukka-Pekka Keisala 90 posts 226 karma points
    Dec 30, 2009 @ 12:08
    Jukka-Pekka Keisala
    Are you trying to link to a page?
    Does umbraco.library:NiceUrl('put your page id here') give you 404 as well?
    Dec 30, 2009 @ 12:14
    lin04com
    Can you speak details?
    Should i need to add some code to any page?
    Dec 30, 2009 @ 13:28
    Dirk De Grave
    lin04com,
    Can you explain what you've done so far? You've installed umbraco, did you install anything in addition (Runway?) You're mentioning a real directory (Did you create this on the file system?) Share that info and we might be able to help you  more accurately.
    /Dirk
    Dec 30, 2009 @ 16:41
    lin04com
    Dirk,
    Yes, there have this folder(/contact-us/) on my file system,and it works very well in asp.net without installed umbraco,and the link is /contact-us/index.aspx.
    Otherwise, on my system, i haven't install anything in addition.
    Now,my question is whether anywhere set the urlrewrite,then the real folder can not be find?
    /Lin04com
    Dec 30, 2009 @ 16:49
    lin04com
    On this site,umbraco back-end management a part of dynamic(like News and Events),others are static pages, such as "/contact-us/index.aspx".
    Can anyone help me?
    Thanks!
  • Sebastiaan Janssen 5061 posts 15523 karma points MVP admin hq
    Dec 30, 2009 @ 16:53
    Sebastiaan Janssen
    Sounds like you need to add /contact-us/index.aspx to the web.config file. In the appSettings section there's a key "umbracoReservedUrls". Any URL's in that setting will be left alone by Umbraco.
    If you have a lot of pages like this, you might want to put them all in the same folder and add that path to the "umbracoReservedPaths" key instead.
    Dec 31, 2009 @ 03:49
    lin04com
    Thanks all!
    Now this issue had resolved .
