  • wojcia 4 posts 24 karma points
    Dec 31, 2009 @ 06:12
    wojcia
    Blog4Umbraco integrated into CWS
    Ok all, before I get my hands dirty in the code, is anyone working on integrating the new Blog4Umbraco (which is FANTASTIC I might add!) in to the CWS style structure?  I know it probably won't integrate cleanly and be usable for everyone, but if there is some statring point, let's see it!
    If not, stay tuned ... I might have something in a couple of weeks (time permitting!).
  • Lee 1130 posts 3088 karma points
    Dec 31, 2009 @ 08:49
    Lee
    Not sure if I am not getting your question but you just need to change blog4umbraco to use the CWS masterpage?  Then it will inherit the CWS styles?
    Dec 31, 2009 @ 18:55
    wojcia
    Possibly ... haven't tried anything yet.  However, since the HTML for the blog is probably a lot different from the layout and HTML of CWS, I'm guessing a lot of the styles will not translate.
    Jan 01, 2010 @ 19:53
    Lee
    It will still inherit the main styles - As in headings, text/font styles, background colours etc..  You will need to tweak some of the styles for the blog as you say but it won't be very much, I started to move the new blog into an existing site this afternoon and it was pretty painless
  • mats lif 1 post 21 karma points
    Apr 16, 2010 @ 23:15
    mats lif
    Hi all
    I installed blog4umbraco but I don't know how to place the blog inside my runaway site..
    I don't want to use a separate hostname for the blog.
    How do I do it?
    (i'm sure that the answer is simple if you know it)
    Best regards Mats
