Have you checked if there has been reported any issues about this on the issue tracker ? - This feature has historically been a bit fragile. But perhaps it can also be related to the server somehow - But I assume that you have checked that it's not because that the server time is different for some reason?
Remove at unpublishes a node instantly
Hi All
I have a website running Umbraco 6.2.0, my client sets a Remove at date on any node and the node is unpublished after only a couple mins.
I've checked the culture, at first the site was running English US, I've changed it to UK, but it hasn't solved it.
The issue is present for all umbraco users.
Any help would be appreciated.
Thanks, Luke
Hi Luke
Hi Jan,
I did find a previous issue that was reported but it was closed without an explanation as to why it wan't fixed.
I have also checked the server date and time. All seems fine on that end.
Thanks.
Hi Luke
Can you post a reference to the issue? That sounds a bit strange - Was it related to other reported issue?
Sorry Jan,
Unfortunately I can't find the reference to the issue I speak of! Can you think of anything else that I could try to get around this issue?
Thanks.
@Luke,
Is the server time set differently than the client time? Or is the client setting the date to an earlier date than today by accident?
