  • Tom 713 posts 954 karma points
    Jan 06, 2010 @ 00:40
    Tom
    XSLT Macro Wrap Page In A Div
    Hi all,
    I want to generate a macro that will wrap some content in my template in a div.
    <div id="body">
        <form id="AdeptMasterForm" runat="server">
    <insert div from macro here with a class name based on current document type>
         <asp:ContentPlaceHolder ID="AdeptMasterContentPlaceHolder" runat="server"></asp:ContentPlaceHolder>
    <close div from macro here>
        </form>
    or alternatively generate the body div above and append a class name using the macro..
    I was wondering how you actually do that where a macro can generate content before then after the template markup.. I was thinking of just rendering the opening tag using the macro but thought surely there must be a better way
  • Hendy Racher 863 posts 3849 karma points MVP 2x admin c-trib
    Jan 06, 2010 @ 01:36
    Hendy Racher
    Hi Tom,
    Is it just the class name of the div that needs to be generated ? ie. the closing </div> always exists ?
    Jan 06, 2010 @ 02:22
    Tom
    Hi Hendy
    Yeah it could be that if it's easier.. i was thinking of just using the macro to render the opening div tag but was wondering if there was an alternative..
    Tom
    Jan 06, 2010 @ 02:58
    Hendy Racher
    Instead of using a macro, could also just make the <div runat="server"... and set the class attribute via the masterpage.
    How is the class name generated ? If it's a property of a node then the umbraco:item control with the insertTextBefore and insertTextAfter attributes could be used.
    HTH,
    Hendy
    Jan 06, 2010 @ 04:25
    Tom
    Hi Hendy..
    basically what i wanted to do was render
    <div class="SomeCategoryName">  where the current or ancestor has an instance of a certain document type
    ie category - correct doctype
          child category 1
          other child category 2
    some other category - not correct doc type
        invalid child category
    so for example "child category 1" and "other child category 2" and "category" would all get something like
    <div class="content categoryNodeProperty>
    and "some other category" & "invalid child category" would just get <div class="content">
  • slashslater 1 post 21 karma points
    Jun 10, 2010 @ 11:09
    slashslater
    Hi Hendy,
    Just like to thank you for your umbraco:item solution. Perfect for my requirement, of allowing a page to dictate what colour scheme to use.
    <umbraco:item field="colourScheme"  recursive='true' insertTextBefore="<div id='CS-" insertTextAfter="'>" runat="server"/>
    outputs perfectly
    <div id='CS-#'>
    can now change which colour scheme a page uses purely by adding a colourScheme field to Doc type.
    It's easy when you know how :)
