Umbraco Version 4.0.2.1 Windows Server 2003 and IIS 6 Exchange 2007
Using CWS for a site and want to use the exchange server send the emails from contact form & email a friend however having issues with getting this to work when you fillin the form and click submit you get the following error:
The
SMTP server requires a secure connection or the client was not
authenticated. The server response was: 5.7.1 Client was not
authenticated
Is there something extra i need to be adding to the web.config apart from the standard smtp section or is there something in exchange i should be looking into?
Has anyone managed to email using an exchange server?
Emailing with CWS and Exchange 2007
If you are using umbraco.library.SendMail you have to set the credentials in the web.config like this:
Check out the msdn documentation if you need more infos
hth, Thomas
And if you are using own code you can set the credentials via
hth, Thomas
