I've written a partial view macro that takes an image as one of the parameters. In the content "design view" (not preview), the image goes outside of the grid column. With a normal image that doesn't happen. How can I get my partial view macro to behave like a normal image and stay within the borders of the grid column in the design view? (It works fine in the page preview).
Are you still having this issue? Could you perhaps share a screendump displaying the issue? Perhaps it's a matter of using max-width:100% in your styling?
As long as I know there is a way of getting the image to fit within the grid in the design view (partial view macro), I can try and work out a way of achieving that. Do you think I need to edit the RTE.css?
Yeah I think you should try either rte.css or style.css and see if you can add img{max-width:100%} so the image will automatically scale to fit the container so it does not look broken.
Umbraco 7 grid partial view macro image width in design view goes outside the grid
Hello.
Leon
Hi Leon
Looking forward to hearing from you.
Hi Jan.
Here is a screen shot.
Hi Leon
Hope this helps.
