  • Mitra 81 posts 196 karma points
    Mar 25, 2015 @ 12:57
    Mitra
    Style missing from the CMS
    I have built a website last year, going back to it to hand it to the clinet and i see that the style from the cms is missing. The front end looks fine, but there is no way client can make any changes.
    I have used umbraco 6.0.6. I even deleted and put a brand new web.config (with my app setting), i deleted the files under App_Data\TEMP\ClientDependency, but it's not solving the problem. I attach the screenshot that you can see.
    Anyone can help me?
    Thanks in advance.
    Mitra
    Mar 25, 2015 @ 13:02
    Hi Mitra
    Do you get any error 404's if you have a look in the console log of the browser? I suspect that it's probably some files that are missing for some reason. It could perhaps also be related to permissions.
    Mar 25, 2015 @ 13:04
    Mar 25, 2015 @ 13:08
    Mitra
    Wow - thank you so much. I copied the files which was missing from the original umbraco copy and it's all working now.
    Many thanks,
    Mitra
    Mar 25, 2015 @ 13:11
    Hi Mitra
    Happy I could help - When something is acting up like that it's usually due to missing files for some reason or the client dependency stuff or permissions.
