  • Fredrik Esseen 610 posts 906 karma points
    Jan 11, 2010 @ 14:48
    Fredrik Esseen
    Using Tinymce public
    Just a thought: Is it possible to use the Tinymce datatype in a usercontrol for external use?
    I was thinking of using the blog package for an intranet where the users dont have to login one more time for creating a blog post.
    Jan 11, 2010 @ 15:41
    Jan 13, 2010 @ 16:15
    Fredrik Esseen
    That worked fine :)
    The only problem now that I cant find a solution to is how to connect to the tinymce that I use in the backend. How is that possible? I want to change what icons and what language that should be used..
    Jan 15, 2010 @ 11:44
    Fredrik Esseen
    Is it possible to use the tinyMCE3.webcontrol.config to get the config-file from the config folder?
  • daniel_sbbs 33 posts 52 karma points
    Aug 11, 2010 @ 14:53
    daniel_sbbs
    Hi, have you found a solution to this topic, I'm also in need of putting an editor on a page in an non-public page and make it work with umbraco (ie get images from media tree)??
    Aug 11, 2010 @ 15:30
    Fredrik Esseen
    Hi!
    Nope, didnt solve it to get the full functionality frpm the backend. But I used some code from this forum app to use the tinymce. But no connection to the media section.
    If you want I can paste the code.
    Aug 11, 2010 @ 15:38
    daniel_sbbs
    Sure that would be great, if I'll come upp with a solution to the other part I will let you know
    Aug 11, 2010 @ 16:15
    Fredrik Esseen
    This is a snippet of the class i use
    include following:
    umbraco.cms.businesslogic.web
    umbraco.cms.businesslogic.propertytype
    public
    partial class CreatePost : System.Web.UI.UserControl
    private ArrayList _dataFields = new ArrayList();
    private int _parentId = -1;
    private umbraco.editorControls.tinyMCE3.TinyMCE _tinymce = null;
    protected void Page_Load(object sender, EventArgs e)
    if (_tinymce != null)
    umbraco.uicontrols.TabView tabview = GetDashboardPanel();
    if (_tinymce.config["umbraco_toolbar_id"] != null)
    _tinymce.config.Remove(
    "umbraco_toolbar_id");
    _tinymce.config.Add(
    "umbraco_toolbar_id", tabview.ClientID + "_tab01layer_menu_sl");
    protected
    override void OnInit(EventArgs e)
    base.OnInit(e);
    // get the blog doctype
    DocumentType blogType = GetBlogPostDocumentType();
    // find any blogs within range of the current user
    SetBlogRoot();
    if (_parentId <= 0)
    blogpostCreatorNoBlog.Visible =
    true;
    blogpostCreator.Visible =
    false;
    else
    // hack to make the tagger datatype work as it relys either on id in request collection
    // or current page in nodefactory
    SetRequestId(_parentId.ToString());
    // load all properties from the first tab
    umbraco.cms.businesslogic.ContentType.TabI contentTab = blogType.getVirtualTabs[0];
    foreach (PropertyType pt in contentTab.PropertyTypes)
    umbraco.interfaces.IDataType dt = pt.DataTypeDefinition.DataType;
    // test for tinymce - we need to tell it to add icons to the dashboard menu
    if (dt.Id == new Guid("{5E9B75AE-FACE-41c8-B47E-5F4B0FD82F83}"))
    _tinymce = (umbraco.editorControls.tinyMCE3.TinyMCE)dt.DataEditor;
    dt.DataEditor.Editor.ID = pt.Alias;
    _dataFields.Add(dt);
    umbraco.interfaces.IData df = pt.DataTypeDefinition.DataType.Data;
    blogpostControls.Controls.Add(
    new LiteralControl(
    new LiteralControl(
    "\">" + pt.Name + " +
    blogpostControls.Controls.Add(dt.DataEditor.Editor);
