  • Peter Bradsted Bodenhoff 27 posts 47 karma points
    Jan 12, 2010 @ 12:56
    xslt-problem with GetMedia
    I have this xslt-file:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
    <xsl:template match="/">
        <xsl:value-of select="umbraco.library:GetMedia($currentPage/data[@alias='frontPicture'], 'false')/data[@alias = 'umbracoFile']" />
    </xsl:template>
    </xsl:stylesheet>
    when i test it in the visualizer it works as I want it to - but when I try to save it I get an error:
    (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer, Boolean closeWriter)
    at System.Xml.Xsl.XmlILCommand.Execute(IXPathNavigable contextDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter results)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
    What is wrong?? .........
  • Peter Dijksterhuis 1442 posts 1722 karma points
    Jan 12, 2010 @ 13:03
    Peter Dijksterhuis
    3
    you have 2 options here:
    1: disable checking for errors upon saving
    2: use the following code:
    <xsl:if test="$currentPage/data[@alias='frontPicture'] != '' ">
    </xsl:if>
    The preview works because you have an active node. Upon saving, you don't have a node to test against, hence the error (Getmedia requires an integer, if nothing present, it's not an integer).
    HTH,
    Peter
    Jan 13, 2010 @ 18:51
    Kim Andersen
    Yeah, you should use the examplecode that Peter wrote in his post.
    Otherwise, you could edit the file outside of Umbraco in some sort of code editor. I myself use Visual Studio all the time.
  • Eric 35 posts 55 karma points
    Jan 14, 2010 @ 10:48
    Eric
    Yes, I think Peter's code (sol. 2) is best practice. I always do that way and never have problem.
  • Lee Kelleher 4026 posts 15836 karma points MVP 13x admin c-trib
    Jan 14, 2010 @ 11:19
    Lee Kelleher
    Hi Peter [BB], yes follow what Peter D suggested, by having an IF condition around the value-of / GetMedia.
    I wrote a blog post a few weeks ago about how to safely handle the GetMedia calls in XSLT - have a read...
    http://blog.leekelleher.com/2009/11/30/how-to-use-umbraco-library-getmedia-in-xslt/
    Cheers, Lee.
