Has anyone else seen this? We've been using Lucene Examine to index a SQL table for several years now and this is the first time I've seen this issue. If the value I am passing is only a single character, say a middle initial, Boost throws "Object reference not set to an instance of an object".
Lucene Examine Boost throws error if value is only a single character
Is there a minimum number of characters you can pass to Examine?
