  • Steve 26 posts 46 karma points
    Apr 08, 2015 @ 19:26
    Steve
    how make banner rotator slide clickable
    Hi I have a banner rotator on my site and I'd like to make the slides have a clickable option to a url. Can I create a property value so that when I load a slide i have the option to add a url to that banner slide so that it could be linked to a url? The slides are added and function as background images in the rotator.
    There is the option to have fly in text captions for each slide. If they could be made clickable that would be a bonus. Almost like a call to action button. Im just not sure as to wether this can be set in properties.
    thx
    Steve
    Apr 08, 2015 @ 19:37
    Dennis Aaen
    Hi Steve,
    I think that you should have a look at the package called uSkySlider from LECOATÌ, with this you can make a slide that has fly in text captions for each slide.
    https://our.umbraco.org/projects/backoffice-extensions/uskyslider and here is a YouTube demo. https://www.youtube.com/watch?v=tCoQNoQRa2s If you want to know more about the package try to see this session from the last year Codegarden conference in Copenhagen. http://stream.umbraco.org/video/9948281/the-sky-is-the-limit
    Hope this helps,
    /Dennis
    Apr 08, 2015 @ 19:48
    Steve
    thanks. It would also solve our responsive issue.
