  • Alessio Rosin 14 posts 71 karma points
    Apr 09, 2015 @ 13:21
    Alessio Rosin
    umbraco7 and russian
    I checked everything
    the backend works and reads and saves in Russian ( field , link and Tinymce3)
    db ( mysql )  saves data in Russian
    if I write in the page view
        Layout = " Master.cshtml " ;
    var texttest = " phrase in Russian " ;
    in backand PROPERLY writes in Russian
    if I write in pageview
    @ CurrentPage.umbHeadline
    writes question marks
    any suggestions?
    Umbraco 7.1.9 - mysql
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Apr 09, 2015 @ 13:34
    Hi Alesso,
    First thing to check is of course if the frontend's encoding is set correct (UTF-8, I presume). Next test would be to make sure that it's not a webfont issue - many webfont services exclude "special glyphs" (special for americans, that is - everyday characters for other people :-)
    That said, I've had problems with masterpages being saved with the wrong encoding - which I could only solve by editing the template locally with an editor that can save in a specific encoding, telling it to save in UTF-8 AND to include the BOM (Byte-Order Mark). Then copy/upload/FTP the file...
    /Chriztian
    Apr 09, 2015 @ 13:41
    Alessio Rosin
    the masterpage it's save in utf8 bom , and the webfont have a cyrilc
    var texttest = " text in  Russian " ;
    @texttest
    it's write in russian
    writes question marks it's a mystary
    same issue in cache file app.data/umbraco.config
