  • Craig O'Mahony 364 posts 918 karma points
    Apr 30, 2015 @ 10:46
    Craig O'Mahony
    Add a default class when anchors are created in the RTE
    Hi folks,
    I'm integrating a design into Umbraco and the designers have specified a few classes that should be applied to anchors
    <a href="#" class="blueLink">Link</a>
    <a href="#" class="blackLink">Link</a>
    <a href="#" class="redLink">Link</a>
    So what I've created is a few styles that can be applied using the formats dropdown in the RTE. All is well and works ok but 95% of the time the class that needs be applied is blueLink and I was wondering if there's any way to apply this class automatically when the user initially creates the link negating the need to select the respective class as it will have already been applied?
    Craig
    Apr 30, 2015 @ 11:29
    Hi Craig
    Wouldn't that be to simply just make the default anchor color inside a rich text editor always be blue? And then the editor will only add classes to those that should be colored differently?
    Say you wrap you rich text editor content in a div with the class rte-content. Like this
    HTML
    <div class="rte-content">
     <a href="#">I don't have a class - I'm just a standard link</a>
     <a href="#" class="redLink">Uuuh! Look at me! I'm a red link - I'm soooo beyond standard.</a>
    CSS
    .rte-content a{
      color:blue;
    .rte-content .redLink{
     color:red;
    Is this approach useful and does it make sense in your context?
    Apr 30, 2015 @ 15:30
    Craig O'Mahony
    Hi Jan,
    Thanks for your response I did think of that but the problem is the design team (who are external) are constantly changing the CSS themselves and I'm concerned that any changes I make to the base CSS will get overwritten on the next update hence the request to try and change the behavior of the RTE.
    Craig
    Apr 30, 2015 @ 16:34
    Hi Craig
    But won't that be a risk no matter the approach you take?
    May 01, 2015 @ 12:48
    Craig O'Mahony
    Actually you're probably right!
    Sorted!
