  • Mikael Mørup 297 posts 326 karma points
    Jan 15, 2010 @ 12:52
    Mikael Mørup
    Macros suddently dissapered
    I had a strange incident with Umbraco  (4.02 on Windwos Vista) this morning.
    When i open the Developers section the Macros folder is empty.
    All the XSLT files for tha macros are still there, and the macros are there somewhere, because i can select them when i use the "inset macro" button in a template.
    They just don't show up in the macros folder. I tried "reload nodes" andi tried to shut everything down an log out, but that did not help.
    Has anybody else experienced this problem ?
    Is there a fix ?
    Thanx
    Mikael
    Jan 18, 2010 @ 10:51
    Mikael Mørup
    Now i double checked everything. The macros are in the DB table. If i add a new macro it shows up in the table. But i still can't see anything in the Marcos folder in the Developer section.
    This is quite scary as i'm prevented from editing my macros.
    Anybod have an idea on how i can make the folder show my macros again ?
    Mikael
    Jan 18, 2010 @ 11:10
    Sebastiaan Janssen
    Sound like a similar issue to the disappearing media topic a few days ago. Maybe that post will help.
    If you create a fresh install of Umbraco and compare the macro tables, you might see something crucial missing..?
    Jan 20, 2010 @ 20:54
    Mikael Mørup
    Hmm it seems to be related to an experiment i made with adding a rightclick menu to the content tree.
    I'm trying to achieve more or less the same as the mail engine from Tim G. does. You right click a node and can send the nodes content as an HTML e-mail.
    So there must be something wrong with my event/menu action code, because as soon as i removed the dll from the bin folder my macros was back.
    Jan 20, 2010 @ 22:01
    Mikael Mørup
    Fixed it!
    I was attaching the menu event to all nodes, but it is only relevant for a smal subset of the nodes, now it is only on the relevant nodes.
    I also had a wrong alias for another menu item that i was finding, to insert my menuitem beneth.
