  • myro 7 posts 27 karma points
    Jan 15, 2010 @ 18:09
    myro
    Macro Parameters, Text and Multiline Text problem: double quotes and breaklines
    Im running
    • umbraco v 4.0.3 (Assembly version: 1.0.3625.27276),
    • asp.net 3.5 on windows server 2008 r2, IIS 7
    I found out that when I create a macro, and add Multiline Text parameter, the text that is insered into the parameter get truncated after a double quote.
    so if I insert into my multiline parameter a text like: hello "world" and publish the page, the text saved into the macro parameter is just hello.
    Infact, if re-edit the macro's parameter, i only see the truncated text.
    An another problem is that text insered into Multiline Text parameter desn't preserve breaklines.
    my macro's xslt:
    <xsl:variable name="Code" select="/macro/Code"/>
    <xsl:template match="/">
     <xsl:value-of select="$Code" />
    </xsl:template>
    As you can see my xslt file does nothing special, it just prints a parameter into my page.
    Am I doing something wrong?
    Any help is really appreactiated.
    Thank you.
  • Lee Kelleher 4026 posts 15836 karma points MVP 13x admin c-trib
    Jan 15, 2010 @ 18:34
    Lee Kelleher
    Hi myro,
    The value of the macro parameter needs to be HTML encoded - which the Umbraco UI usually does for you.
    If you are manually editing the value, then you will need to encode the text.  If you are not sure about the HTML encodings, there is a reference guide:
    http://www.w3schools.com/tags/ref_entities.asp
    Cheers, Lee.
    Jan 16, 2010 @ 11:32
    myro
    Hello Lee,
    Thank you for your response.
    I have already tried to html encode the text, but with the same result:
    •  hello &quot;word&quot;   is truncated to  hello
    • hello &#34;word&#34;  is truncated to hello
    I really can't understand what is going wrong: after publishing the page, all the text  after &quot;  or &#34; is lost.
    Is there maybe a configuration that should be set?
    Jan 16, 2010 @ 20:00
    myro
    Could anybody please, just try to paste " hello &quot;word&quot;  "  into a text/multiline text macro's parameter and publish the page to see if the same problem happens?
    Thank you
  • Matt Nolan 45 posts 65 karma points
    Apr 04, 2012 @ 17:56
    Matt Nolan
    Hi myro,
    I have the same issue, did you ever find a solution?
    Matt
  • Thomas Egebrand Gram 63 posts 138 karma points
    Sep 21, 2012 @ 14:29
    Hello!
    Experiencing the same problem - will post if i figure something out.
    // Thomas G
