I am trying to use umbracoUrlAlias to support old urls. I added umbracoUrlAlias to my document type. Then, I added the old url (no leading slash or trailing .aspx) to the content. The path in the umbracoUrlAlias returns a 404.
I have already verified that this exists int he 404.config- <add key="umbracoUseDirectoryUrls" value="true" />
The standard URLs do work. It appears that the "magic" umbraco UmbracoUrlAlias property is not catching. I have an HttpModule that we built that will handle a large number of redirects and uses a central data source to do so. I was hoping to use the umbraco built in support though.
Casey - I'll email you if we need to go that route.
Turns out that there is more of a unexpected behaviour.
If i use the property in a subpage to a root-node (as in handeled by host name) it does work. But not if it is used on the root.
Example:
domain.local/ is named 'Whatever', thus the link domain.local/whatever work. That node has a umbracoUrlAlias set to 'somethingelse', wich DOESNT work. It returns a 404.
domain.local/subnode is named 'Sub Node', and returns 200 on domain.local/subnode. Also, if the umbracoUrlAlias is set to 'somethingelse', it DOES return a 200 on domain.local/somethingelse.
As far as my brain works, this behaviour cannot be correct.
Umbraco uses the UrlRewriting.net library and you can add your own rules to the UrlRewriting.config. I had the same issue and that's what I did to solve it for the time being.
umbracoUrlAlias not working
umbraco 4.0.2.1
What else am I missing?
It may be a dumb question, but do the standard URL's still work with the page? Do they work extension-less?
Tommy,
I have a simple user control that redirects a set of URLs to new paths that works with 404 pages.
Email me at casey at best case tech dot com, and I will share the package with you.
i am refering to http://www.mayflymedia.co.uk/blogs/alternate-page-name-in-umbraco-using-umbracourlalias
But umbracourlalias is not working . Please advice how can i remove "aspx" from url to make it user friendly ?
Shruti
Im having the same problem in Umbraco v 4.7.2 (Assembly version: 1.0.4500.21031).
All the other default/hidden/internal properties work.
My implementation has worked before on other versions, following Warrens how-to @ http://our.umbraco.org/wiki/reference/umbraco-best-practices/umbracourlalias
Is it a bug in the later versions?
Any takers?
Example:
http://umbraco.codeplex.com/workitem/30851
I am using Umbraco 7.1.6 and it seems not working.
Does it require any configuration.
I have created a propery with "umbracoUrlAlias" and adding comma seperated value.
Keyur.shah,Keyur786Shah but it gives 404.
Any help would be appreciated.
-Thanks
PS: My first post.
Hi Keyur,
At which level is the node that you are setting
umbracoUrlAlias?I believe that
umbracoUrlAliaswill only add an alias for that node's level - not the absolute URL.Thanks,
- Lee
Hi Lee,
In my tree
-Root Node
-Profile Node (I am setting Url alisae)
-Child node
so the url will be like localhost/keyurShah(Alias= keyur786shah)
But I think I figured that out as I was manipulating the url segment and so it wasnt working.
Keyur
