I'm sorry, but I don't understand what the code snippet has to do with your issue. Also the link you've provided doesn't seem to work.
Umbraco doesn't interfere with you HTML/CSS/JavaScript, so the problem you're having is most likely that there's something wrong with the select you're doing in jQuery.
Jquery Innerfade and Umbraco
I am having trouble getting jquery innerfade to pull the class .innerfade. I am getting to the UL ID in the xslt but then it stops.
XSLT
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]>
<xsl:stylesheet
version="1.0"
<xsl:variable name="MediaRootId" select="$currentPage/data [@alias = 'MediaRoot']"/>
<xsl:template match="/">
<!-- start writing XSLT -->
<xsl:if test="$MediaRootId != '' ">
<!-- just added as cast-workaround -->
<ul id="portfolio">
<xsl:for-each select="umbraco.library:GetMedia($MediaRootId, 'false')/node">
<li>
<xsl:if test="@nodeTypeAlias='Image'">
<xsl:element name="img">
<xsl:attribute name="src">
<xsl:value-of select="data [@alias = 'umbracoFile']"/>
</xsl:attribute>
</xsl:element>
</xsl:if>
</li>
<!-- Add other <td> entries here to display further info -->
</xsl:for-each>
</ul>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
The images are listing down the page
you can see the site at http://altavistaymce.org on the home page
http://altavistaymca.org
