  • karen 186 posts 461 karma points
    Jan 20, 2010 @ 22:51
    karen
    adding styles to tinymce
    I want to create styles to use in the rich text editor. I've gone to settings->stylesheets and created a stylesheet.
    I have pasted some styles into the big text area that appears there, but they do not show up in the styles droplist while in the editor.
    I did create one by clicking 'create' and filling out the form and that one does show up.
    Is the only way to add styles is to click 'create' for each one?  If so, why is there a big text area there?
    Karen
    Jan 20, 2010 @ 23:21
    Kim Andersen
    Hi Karen
    Yes hat is the way to do it. First of all, you need to have a master-stylesheet attached to your Richtext Editor. Underneath this stylesheet, you must create all the different styles you need in the "Style"-dropdown. One by one.
    Jan 20, 2010 @ 23:54
    karen
    So that is the only way?  I can't just paste a bunch into the text area?  What is the text area for?
    Jan 21, 2010 @ 22:52
    Kim Andersen
    Not as far as I know Karen. Unfortunately. I don't know why the textarea is as big as it is. Maybe some of the more routined users can answer this.
    /Kim A
  • Mikael Mørup 297 posts 326 karma points
    Jan 21, 2010 @ 23:01
    Mikael Mørup
    The big textarea is for a standard CSS style sheet you can link in your templates using the standard notation like:
        <link href="/CSS/MasterStyles.css" rel="stylesheet" type="text/css" />
    The styles defined in there will be applied to the matching elements in your pages based on that template.
