  • James Hildeman 92 posts 88 karma points
    Jan 21, 2010 @ 19:00
    James Hildeman
    Removing "Public Access" doesn't work on fully secured site
    I'm using Umb v3.0.5.  Assume the following (desired) content tree.
    Content
    - Home (restricted to only group members)
      + Intro  (restricted to only group members)
      + Steps  (restricted to only group members)
      + Help  (restricted to only group members)
      + Tools (public)
        -- Login
        -- Register Now
        -- Forgot Password
    As you can see, I am building a secured site with just a few public pieces to allow people to get started.  To implement this, I have used advanced "public access" and secured every from the home page level on down to group "members".  The problem my Tools area.  I need that to be publically available so people can register or retrieve a forgotten password.
    When I right-click, "public access" on Tools I click the "Remove Protection" button.  It returns and says "Removed Protection from Tools".  Alas, it did not.  Register now is still protected and simply forces the login page first.
    What am I doing wrong?  Tell me he is not assuming everyone underneath is protected.
    Thanks in advance,
    Jim
    P.S.  I am techie enough so if this is bug, please explain how to backdoor this through the database or access.xml if that is necessary.  I'm unclear on the role of access.xml since I deleted it and it does not get recreated even when I publish all, repub entire site or set "public access" on a node.
    Jan 22, 2010 @ 11:46
    Morten Bock
    I am afraid that public access _is_ inherited as far as I know. I haven't used it that much, but this might be a usable workaround:
    Content
    - Landing (Public, but redirects to "Home")
      + Home  (restricted to only group members)
      + Tools (public)
        -- Login
        -- Register Now
        -- Forgot Password
    Could that work for you?
    Anyways, I think it might be a good point that you should be able to override protection on a subpage, so you could add that as a request on Codeplex.
    Jan 22, 2010 @ 15:56
    James Hildeman
    Thanks tons!  I just ran through this.  Your solution worked like a champ.  Life is good again.
    Jim
