  • Jukka-Pekka Keisala 90 posts 226 karma points
    Jan 26, 2010 @ 12:36
    Jukka-Pekka Keisala
    How does normal editor changes his/her password
    It seems to me that there is "My Profile"  missing in Umbraco where I could change password.
    How do you usually do this? Would you give editor access to Users section?
  • Seth Niemuth 275 posts 397 karma points
    Jan 26, 2010 @ 15:33
    Seth Niemuth
    Unfortunately, there is no place for this. I created a macro that you can add to any page which will allow any logged in user to change their password:
    http://our.umbraco.org/projects/my-info
  • Cem Sisman 33 posts 31 karma points
    Jan 26, 2010 @ 16:44
    Cem Sisman
    link is not working
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    Jan 26, 2010 @ 17:09
    Jan 26, 2010 @ 18:05
    Seth Niemuth
    sorry, i made it my-info and then i changed the name of the project so it would come up in appropriate search results.
    Jan 27, 2010 @ 12:21
    Jukka-Pekka Keisala
    Would be nice though having possiblity to change personal detail somewhere next to Help button but in the other hand not sure if this should be default functionality.
    Anyway, thanks Seth for nice macro.
    Jan 27, 2010 @ 14:39
    Seth Niemuth
    That is a good suggestion. I figured out how to do it easily...you just have to change 2 files (only one if you dont want to mess with languages). There is a screenshot of the button on my project: http://our.umbraco.org/projects/my-info---change-user-password-and-email
    If you want to add a button on the backend next to the about button you can do this (Backup files before you edit them):
    Edit the /umbraco/umbraco.aspx and find the  <div class="topBarButtons">
    Inside of it, add this button and image (with '/MyInfo.aspx' being the URL to your web page with the control:
     <button onclick="window.open('/MyInfo.aspx','help','width=750,height=500,scrollbars=auto,resizable=1;'); return false;" class="topBarButton">
                        <img src="images/newStar.gif" alt="about" /><span><%=umbraco.ui.Text("general", "myprofile")%></span></button>
    Then, you will need to add text for 'myprofile' in the general area of your language file.
    Language files are in /umbraco/lang/
    My en.xml file now has
      <key alias="myprofile">My Profile</key>
    Inside <area alias="general">
