I have a menu which seems to behaving properly on most previews, but when I go to portrait mode for a Tablet, it does not collapse the menu, instead it pushes it down. Here is code for the master page
Layout = null;
var home = @CurrentPage.Site();
<!DOCTYPE html>
<html lang="en">
<head>
<!-- Meta tags -->
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1">
<meta name="description" content="@CurrentPage.siteDescription">
<title>@CurrentPage.Name | @CurrentPage._siteTitle</title>
<!-- Fonts -->
<link href="//fonts.googleapis.com/css?family=Merriweather:400,700,300,900" rel="stylesheet" type="text/css">
<link href="//fonts.googleapis.com/css?family=Lato:300,400,700,900" rel="stylesheet" type="text/css">
<!-- CSS -->
<link rel="stylesheet" type="text/css" href="/css/bootstrap.min.css">
<link rel="stylesheet" type="text/css" href="/css/style.css">
<!-- HTML5 shim and Respond.js for IE8 support of HTML5 elements and media queries -->
<!-- WARNING: Respond.js doesn't work if you view the page via file:// -->
<!--[if lt IE 9]>
<script src="//oss.maxcdn.com/html5shiv/3.7.2/html5shiv.min.js"></script>
<script src="//oss.maxcdn.com/respond/1.4.2/respond.min.js"></script>
<![endif]-->
</head>
<body>
<header>
<div class="container-fluid">
<div class="row">
<div class="col-xs-12">
<nav class="navbar navbar-default">
@{ Html.RenderPartial("MainNavigation"); }
</nav>
</header>
@RenderBody()
<footer>
<div class="container">
<div class="row">
@*@{ Html.RenderPartial("BottomNavigation"); }*@
</footer>
<!-- Javascripts -->
<script src="/scripts/jquery-1.9.1.min.js"></script>
<script src="/scripts/bootstrap.min.js"></script>
</body>
</html>
Here is code for the MainNavigation:
@inherits UmbracoTemplatePage
This snippet displays a list of links of the pages immediately under the top-most page in the content tree.
This is the home page for a standard website.
It also highlights the current active page/section in the navigation with the css class "current".
@{ var selection = CurrentPage.Site().Children.Where("Visible"); }
<div class="navbar-header">
<button type="button" class="navbar-toggle collapsed" data-toggle="collapse" data-target="#bs-example-navbar-collapse-1" aria-expanded="false">
<span class="sr-only">Toggle navigation</span>
<span class="icon-bar"></span>
</button>
<a class="navbar-brand" href="~/">Brand</a>
<div class="collapse navbar-collapse" id="bs-example-navbar-collapse-1">
<ul class="nav navbar-nav">
@foreach (var item in selection)
<li class="@(item.IsAncestorOrSelf(CurrentPage) ? "active" : null)">
<a href="@item.Url" class="@(item.Name.Equals("Product Search")? "glyphicon glyphicon-search" : null)">
@item.Name
</a>
</li>
</ul>
Bootstrap menu is not collapsing in Tablet Portrait Preview
Here are a couple images:
Tablet landscape:
Tablet Portrait:
