  • Mikael Mørup 297 posts 326 karma points
    Jan 28, 2010 @ 11:28
    Mikael Mørup
    Installing 4.0.3 error
    im trying to install a fresh Umbraco 4.0.3 on a Windows  2008 server.
    After messing with the app pool and setting the app pool owner to network service i try to run http://localhost but i get a debug trace with this error:
    Trace Information
    CategoryMessageFrom First(s)From Last(s)
    aspx.page Begin PreInit
    umbracoInit handling request 4.07873067666421E-05 0.000041
    Unhandled Execution Error
      at umbraco.UmbracoDefault.Page_PreInit(Object sender, EventArgs e)
      at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e)
      at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
      at System.Web.UI.Page.OnPreInit(EventArgs e)
      at System.Web.UI.Page.PerformPreInit()
      at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    0.000413460369963222 0.000373
    I have set the correct security level on all Umbraco dirs, and i use the default integrated IIS7 app. pool.
    What am i missing ?
    Mikael
    Jan 28, 2010 @ 11:30
    Mikael Mørup
    Just an addon to the previous post
    i'm using the web.config file supplied for .net 3.5 on codeplex
  • Jonathon Alsop 4 posts 24 karma points
    Jun 13, 2011 @ 06:49
    Jonathon Alsop
    Did you ever get to the bottom of this??
