  • Luke 110 posts 256 karma points
    Jul 16, 2015 @ 12:55
    Luke
    Viewing File In Media Section
    I have a form in the frontend with which users can upload a file (PDF, DOC, etc). I save this file using the Media api's all works fine.
    However when you click on the file in the media section there is no way of downloading the file or viewing. How would my administrators view this file without copying the URL that is in the textbox??
    Thanks and Regards L
    Jul 16, 2015 @ 13:08
    Dennis Aaen
    101
    Hi Luke,
    If you click on the pdf file in the media section then you should see a picture something like this below.
    If you click on the URL in textbox then the PDF file open up in the browser.
    Hope this helps,
    /Dennis
    Jul 16, 2015 @ 13:16
    Luke
    I feel silly now, thank you - I thought it was free text in the textbox.
    Jul 16, 2015 @ 13:18
    Dennis Aaen
    Hi Luke,
    You are welcome, happy that I could help you find a solution to your case.
    /Dennis
