  • prl 32 posts 54 karma points
    Jan 29, 2010 @ 17:46
    prl
    Ratings Module
    One thing that seems to be very useful in a CMS like Umbraco is a ratings module so that the users can rate each article they read. Is there anything already created for that purpose?
    Thanks in advance.
  • Daniel Lindstrom 454 posts 271 karma points
    Jan 30, 2010 @ 02:30
    Daniel Lindstrom
    Tim made a star rating package about two years ago:
    http://www.nibble.be/?page_id=4#starrating
    Feb 03, 2010 @ 11:38
    prl
    Thank you for your reply.
    Is there any "guide" for installing and using this? I'm getting an error when I try to use it:
    Invalid object name 'xtraStarRating'.
    Exception Details: System.Data.SqlClient.SqlException: Invalid object name 'xtraStarRating'.
    This happens when I pass the parameter "RatingBarUniqueId" (if I don't pass that parameter I get an obvious error stating that I need to pass it).
  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Feb 05, 2010 @ 10:20
    Tim
    Are all of the tables set up in the database for the plugin? That error looks like you're missing a table called "xtraStarRating".
    Feb 05, 2010 @ 10:36
    prl
    I installed the package (downloaded it and installed through Umbraco)... it should create all necessary tables right? I don't any table with that name in my DB.
  • Piotr Bach 18 posts 138 karma points c-trib
    Oct 12, 2021 @ 10:04
    Piotr Bach
    Hi, now Star Rating Property Editor is avaliable.
    Best, Piotr
