  • Lee 1130 posts 3088 karma points
    Feb 06, 2010 @ 13:50
    Lee
    Admin Error Help! Object reference not set to an instance of an object
    Bit of a major problem just occurred, a live site's admin section is constantly throwing the following error if you click on any node in the site tree??
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
    Source Error:
    Stack Trace:
       umbraco.controls.ContentControl.addControlNew(Property p, TabPage tp, String Caption) +54
       umbraco.controls.ContentControl..ctor(Content c, publishModes CanPublish, String Id) +756
       umbraco.cms.presentation.editContent.OnInit(EventArgs e) +368
       System.Web.UI.Control.InitRecursive(Control namingContainer) +333
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +378
    Version Information: Microsoft .NET Framework Version:2.0.50727.3603; ASP.NET Version:2.0.50727.3082
    It was working fine this morning, only thing I know of that's changed is client set two articles to publish today @ 12.00 using the 'publish at' feature?  Now when I login, click on the home node or any other and I get this?
    I have checked the UmbracoLog and this is the log
    At /umbraco/editContent.aspx?id=1235 (Referred by: http://www.mysite.co.uk/umbraco/TreeInit.aspx): System.NullReferenceException: Object reference not set to an instance of an object.
       at umbraco.controls.ContentControl.addControlNew(Property p, TabPage tp, String Caption)
       at umbraco.controls.ContentControl..ctor(Content c, publishModes CanPublish, String Id)
       at umbraco.cms.presentation.editContent.OnInit(EventArgs e)
       at System.Web.UI.Control.InitRecursive(Control namingContainer)
       at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    I have to pop out now, but need to get this sorted quickly as soon as I return?  Any ideas of what could have caused this?  Anyone experienced anything similar when using the 'publish at' feature
  • Jamie Howarth 306 posts 773 karma points c-trib
    Feb 06, 2010 @ 15:03
    Jamie Howarth
    Very very odd. DM me and I can help debug if you want :-)
  • Aron Gamble 63 posts 76 karma points
    Feb 06, 2010 @ 15:22
    Aron Gamble
    Check the app pool. Whenever i get this i restart the app pool / site and the problem goes away.
    Feb 06, 2010 @ 16:26
    Lee
    Damn :(  Restart didn't work
    Media is also dead?  Click on any node and get the same error?  Going to have a look around the DB now and see if I can see anything out the ordinary?
    Only thing that I can pin this on is something to do with the publish at feature?
    Feb 06, 2010 @ 16:37
    Lee
    Can't see anything out of the ordinary in the database?  I'm going to keep looking but anyone have any other ideas of where I should be looking?
  • Peter Dijksterhuis 1442 posts 1722 karma points
    Feb 06, 2010 @ 16:47
    Peter Dijksterhuis
    Can it be a missing dll in the bin-folder? Or perhaphs someone copied an older version into it?
    Feb 06, 2010 @ 16:52
    Lee
    Its a DB problem, I restored a backup from yesterday and its working fine again?  I'm thinking it might be down to a datatype value change which a lot of nodes reference.
    When DropDownList DataType's are used on a node, is the Text & Value stored? or just the Value (The ID)?
    Feb 06, 2010 @ 17:06
    Peter Dijksterhuis
    As far as I know just the value.
    Makes sense that the error occurs if a particular ID has gone missing
    Feb 06, 2010 @ 17:26
    Lee
    Thats whats weird, the ID stayed the same - Only the Text value changed as there was a spelling mistake.  Its either the datatype text value being changed, or something to do with the publish at feature.
    At the moment I'm moving towards the DataType Text value as this was changed in the database?  But I thought only the ID was stored so it wouldn't make a difference to nodes referencing the datatype :S
  • Richard Soeteman 4051 posts 12924 karma points MVP 2x
    Feb 07, 2010 @ 08:41
    Richard Soeteman
    HI Lee,
    Probably a modification on a doctype caused this issue. All properties are updated during that proces but not in a transaction which means that if one fails this error occurs. Had it once on a live site also and wrote a blogpost how to solve it so check that out here
    Hope it helps you,
    Richard
    Feb 07, 2010 @ 09:19
    Lee
    Great post Richard :)  Thanks
    Feb 19, 2010 @ 16:02
    Jamie Howarth
    Just had this happen here with a site in dev environment. Thanks for the heads-up :-)
  • MrFlo 159 posts 403 karma points
    Jan 24, 2011 @ 23:13
    MrFlo
    I had the same error after a modification in a document type as well. It was a new child document type.
    I deleted it and everything was working correctly after that :-)
  • Craig Taylor 29 posts 69 karma points
    Feb 25, 2011 @ 16:13
    Craig Taylor
    Encountered the same issue after manually deleting all instances of a property and then the property itself directly from the database.  I recycled the app pool as suggested and everything looks good now.
    Thanks!
    Craig
