  • Jonas Eriksson 930 posts 1825 karma points
    Feb 08, 2010 @ 14:50
    Jonas Eriksson
    Users: "Start Node in Content" disappeared
    Dooh, I lost the setting for "Start Node in Content" in settings for a particular user. I had it before on this site, and I havent added any odd things recently. Now that I need it quick, and it's gone... Only thing I did change was I moved the previous "start node in content" one level down, and changed it's name. Could that cause this error?
    TIA
  • Nik Wahlberg 639 posts 1237 karma points MVP
    Feb 08, 2010 @ 14:56
    Nik Wahlberg
    Do you mean that you don't see the setting at all anymore? Or, you can't locate the node to start in?
    nik
    Feb 08, 2010 @ 15:00
    Jonas Eriksson
    Hi Nik!
    The whole setting is lost, for other users it's there, right above "Start node in Media".
    Feb 08, 2010 @ 15:02
    Nik Wahlberg
    Hmmm, afraid I can't say I've ever seen that before. Sorry.
    Feb 08, 2010 @ 15:03
    Jonas Eriksson
    I tried add another user for this, it's added, but when I try change anything I get an error "Error saving user (check log)". The log only say : Error, User cannot be updated.
    The site is a pretty well-ordered one, with no tweaks or specialities afaik.
    Feb 08, 2010 @ 15:21
    Jonas Eriksson
    I made it work by adding yet another user and set the correct folder. Works, but setting is gone now, so I cannot change it for that user. Need to get on with other stuff, will get back to this another day. Perhaps there's already a issue at codeplex for this.
  • Laura Zandarin 3 posts 23 karma points
    Feb 24, 2010 @ 11:38
    Laura Zandarin
    Hi, i got the same problem of lost "Start Node in Content", when i create a new user i can set it but
    after i made it the setting chenge disappears !!! I need to change it for some users how can i do?
    Please help me. Tanks,
    Laura
    Feb 24, 2010 @ 11:46
    Dirk De Grave
    Laura,
    If having issues changing it from the backend, I'd suggest to change the settings in the db directly (umbracoUser table) and report this issue on Codeplex as well so it gets resolved in future release!
    TIA,
    /Dirk
    Feb 24, 2010 @ 12:06
    Laura Zandarin
    Thanks Dirk,
    i go straightly to report it on Codeplex. Unfortunatly i don't have no more the direct access to db so i urgent need to found another way to change it.
    Laura
    Feb 24, 2010 @ 12:37
    Dirk De Grave
    Bummer... but you could still script the changes if you know the user id's and start node to set, or have someone local to do the changes...
    /Dirk
    Feb 24, 2010 @ 13:02
    Laura Zandarin
    For this time i think I become a "local" to make changes ....
    Laura
    Feb 26, 2010 @ 17:00
    Jonas Eriksson
    Tried this in 4.1.b2 and the problem seems to have been fixed.
