  • Biagio Paruolo 1619 posts 1912 karma points c-trib
    Aug 16, 2015 @ 11:44
    Biagio Paruolo
    TinyMCE3: How to add styles to the editor?
    How to add styles to the editor? I associated my css website file into TiniMCE datatype, but don't read any info from css. Thx
  • Marc Goodson 2157 posts 14431 karma points MVP 9x c-trib
    Aug 16, 2015 @ 17:54
    Marc Goodson
    Hi Biagio
    The formats dropdown in the editor doesn't automatically populate from the stylesheet associated with the rich text editor.
    For each style you want to make available in the dropdown you need to add a stylesheet property - locate the associated editor stylesheet in the stylesheets section, right click and create - give your new style property a name (to view in the dropdown) and an alias, the css syntax to apply, these style rule options are then the items that appear in the style dropdown in the rich text editor. If that makes sense ?
    (You may need an app pool refresh for the options to appear, depending on umbraco version)
    Aug 16, 2015 @ 20:12
    Dennis Aaen
    Hi Biagio,
    Try to have a look on this video on how to add styles to the editor.
    http://umbraco.tv/videos/umbraco-v7/implementor/fundamentals/stylesheets-and-javascript/setting-up-rte-styles/
    Hope this helps,
    /Dennis
