I've added at style for "blockquote" for tinymce, Settings/Stylesheets/tinymce/ the style is named "Blockquote" and in field alias I also entered Blockquote
The style shows up nice in tinyMce editor styles-dropdown. And when I use it with FF the html is changed to <blockquote>selected text</blockquote> as I like. Same goes for Chrome. But in IE nothing happens.
Other styles, like h1, h2, h3 works fine in IE though.
Ok, perhaps not the perfect solution since one needs to go inside the tinymce scripts. However I will give it a shot, and I add this post since it might be helpful for others with the same problem.
Ok, so now I answered my own q... But if someone has another (more straightforward) solution to this, please say a word :-)
A (perhaps related) problem I had with tinyMCE when using blockquote was that tinyMCE would create blockquotes as well as adding a class of "blockquote" to paragraphs inside the quotes. It also had problems closing the blocks at the correct place when paragraphs were inside them.
I had to change it to ".blockquote" and make <p>'s with a class of blockquote. Semantically inferior, but life is a little easier now ^^.
tinyMce add style does not work completely in IE
Hi!
... pause ...
Ah, while writing this I got a google hit on the problem... http://tinymce.moxiecode.com/punbb/viewtopic.php?id=14811
Hm, yeah. Definately better than not working at all. Thanks!
Another issue here is that <blockquote>mmm</blockquote> is not valid xhtml, should be a <p> included as well.
