  • jernej 7 posts 28 karma points
    Feb 13, 2010 @ 03:57
    jernej
    Problems with Obout controls in Umbraco 4.0.2.1
    Hi, I'm experiencing some difficult problems using Obout controls (http://www.obout.com/) on my page in Umbraco. All of the controls work well except for Obout.ListBox & Obout.ComboBox which do not work If I have this two controls on a .ascx control that has a asp.net DetailsView control and an ObjectDatasource....when I connect the DetailsView and ObjectDataSource via DataSourceId the obout.ListBox and obout.ComboBox become plain input fields??? I realllly dont get it, I also tested outside of Umbraco and it works well?  Thanks for your help!!
    Feb 13, 2010 @ 14:57
    jernej
    update...
    the control just does not work if it is inside a asp:detailsView control
