  • Ajay Rathod 8 posts 77 karma points
    Oct 17, 2015 @ 07:52
    Ajay Rathod
    URl Rewriting To Try Dynamically
    Hello EveryOne , I Am Try Dynamic Write code In UrlRewriting.config for Url-Rewrite and Redirect For Url :-
    http://www.test.com.au/test1/test2/test3/test4/test5/
    I am Use This Code For 5th Level Of Url-Rewrite and Redirect:-
      <add name="redirect_test_level4/5" redirect="Application" redirectMode="Permanent" virtualUrl="^~/test1/(.*)/(.*)/(.*)/(.*)/(.*)/$" rewriteUrlParameter="IncludeQueryStringForRewrite" destinationUrl="~/$4/$5" ignoreCase="true" />
    <add name="test-rewrite-level2"
                    virtualUrl="^/(test5)/(.+)/?$"
                    rewriteUrlParameter="ExcludeFromClientQueryString"
                    destinationUrl="/test1/test2/test3/test4/$1/$2"
    Get Results :-
    http://www.test.com.au/test4/test5
    Any Idea To Done Dynamic URL Rewriting And Not Any Name Use For Reference To Write In Code , Please Reply Best Solution .
    Thanks In Advance ...Regard Ajay Rathod
  • Paul Seal 524 posts 2890 karma points MVP 7x c-trib
    Jan 21, 2016 @ 18:30
    Paul Seal
    Hi Ajay Try my solution in this article. Please let me know if it helps? http://www.codeshare.co.uk/blog/create-a-redirect-page-in-umbraco-without-editing-the-config-file/
    Paul
    Jan 22, 2016 @ 13:59
    Ajay Rathod
    Thanks Paul Seal for reply , I am try dynamically Url-Rewrite and Redirect ,not static name to use for Url-Rewrite and Redirect . For example Write code In UrlRewriting.config for Url To Rewrite and Redirect try dynamic :-
    https://www.test.com.au/test1/test2/test3/
    <add name="redirect_test-level1" redirect="Application" redirectMode="Permanent" virtualUrl="^~/test1/(.*)/(.*)/$" rewriteUrlParameter="IncludeQueryStringForRewrite" destinationUrl="~/$1/$2" ignoreCase="true" />
    <add name="test-rewrite-level1"
                 virtualUrl="^/(.+)/(.+)/?$"
                 destinationUrl="/test1/$1/$2"
    its Working and get result :-
    https://www.test.com.au/test2/test3
    but try one more level add for Rewrite and Redirect Url :-
    https://www.test.com.au/test1/test2/test3/test4/
    <add name="redirect_test-level2" redirect="Application" redirectMode="Permanent" virtualUrl="^~/test1/(.*)/(.*)/(.*)/$" rewriteUrlParameter="IncludeQueryStringForRewrite" destinationUrl="~/$2/$3" ignoreCase="true" />
                 virtualUrl="^/(.+)/(.+)/(.+)/?$"
                 destinationUrl="/test1/$1/$2/$3"
    Its working only redirect not rewrite and show 404 page Error . if any idea or solution this problem ,please reply
