Macro: can't use a treemultipicker data type for a parameter?
If that's so, then how can I create a macro that gives me the ability to select, say multiple products that I want to display in an html content documenttype...?
Otherwise, you could enter a comma separated list of node ids as a text file (pita for editors) or pick a parent node if your structure is appropriate.
Well, my real question is why are macro properties unable to reference data types? a checkboxlist would be useful in passing parameters to a macro as well as a documenttype, and since a macro is more of a snipplet...
I would like to use UltimatePicker or TreeMultiPick to select products to be displayed on a particular page, but looks like i'll have to rewrite a whole bunch of code that should just simply be usable in the macro properties as well...
No need to rewrite a whole bunch of code, it's just a matter of implementing a single interface IMacroGuiRendering. Anyway, if you think this is really missing from umbraco, you should create a work item on Codeplex and vote for it. If it gets enough votes, it'll be considered a feature for a future release (decision still taken by core team - which pretty much follows the 80/20 rule). If it doesn't get enough votes, well, maybe not so many people really have a need for such a macro parameter.
Oh, umbraco is open source, so why not build this macro parameter type yourself and release it to the community?
There's nothing like that OOB, but you could try looking at http://www.richardsoeteman.net/CommentView,guid,24E1D561-1F6C-4411-BD62-584023D31DF7.aspx (and http://our.umbraco.org/forum/developers/api-questions/6323-Help-with-creating-a-Macro-Parameter-Type)
Dan
Am i wrong here?
I totally agree Eric ... it seems strange and I find makes the Macro Container pretty unwieldy
Eric, Essy
/Dirk
