  • Tom 713 posts 954 karma points
    Feb 17, 2010 @ 01:38
    Tom
    Bulk Move Nodes
    i was just wondering if there was a way to move multiple nodes from one tree folder to another.. I restructured part of my site and wanted to move a pile of nodes at the same time..
    Tom
    Feb 17, 2010 @ 08:51
    Hi Tom
    If you right click on a node you can see there is an option called "move". If you click "move" on your parent node, you move all your nodes all at once and your job is done! :)
    Hope this helps.
    Feb 25, 2010 @ 01:36
    Tom
    Hi Jan,
    thanks for your reply..
    but won't move being called on my parent node, move the parent node also?
  • Heather Floyd 610 posts 1033 karma points MVP 7x c-trib
    May 27, 2010 @ 22:32
    Heather Floyd
    4
    Yes, if you "move" the parent node, it moves the parent AND its children all together.
    I wish there were an easy way to move ALL the children from one node to another (like an additional option in the right-click menu like "Move all children") An even more flexible solution would be for umbraco's content tree to allow multi-select, then operations could be performed on all the selected items.
    ~Heather
  • Amir Khan 1289 posts 2746 karma points
    May 27, 2010 @ 23:48
    Amir Khan
    I second Heather's solution, multi-select would rock bigtime.
  • Bram Loquet 72 posts 102 karma points
    May 28, 2010 @ 16:40
    Bram Loquet
    I second Heathers and Amir, this would be awesome.
  • Alex Lindgren 159 posts 356 karma points
    Feb 11, 2011 @ 23:09
    Alex Lindgren
    I third this... I voted for this on codeplex: http://umbraco.codeplex.com/workitem/29800
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Feb 12, 2011 @ 07:04
    Richard Soeteman
    3
     I've written the Content Maintenance Dashboard package. with version 1.2 it's possible to bulk move nodes
    Hope this helps you,
    Richard
