  • Subhra Bhattacharjee 4 posts 73 karma points
    Nov 10, 2015 @ 11:56
    Umvbraco 4.8.1 tutorial
    Could anyone please help by sharing some tutorial on Umbraco version 4.8.1. I am completely new to it and have to start working on a project using version 4.8.1. Please share the tutorial. It would be of great help. Thanks in advance
    Nov 10, 2015 @ 11:58
    Sorry.. I did not want to create any spam post. I know version 4.8.1 is obsolete, but i desperately need some help with it. I have work on an existing project which is using Umbraco v4.8.1. Please help
  • Ravi Motha 290 posts 500 karma points MVP 8x c-trib
    Nov 10, 2015 @ 13:05
    Ravi Motha
    Depending on what you are actually trying to do, I think a lot of the content for Document types , etc will be applicable from 4.7.11
    I'd use that as a base and then try and ask questions based on indicidual difficulties going forward.
    ravi
    Nov 10, 2015 @ 14:55
    I'll do that Ravi... Thanks
  • Steve Morgan 1349 posts 4459 karma points c-trib
    Nov 10, 2015 @ 13:57
    Steve Morgan
    Have you used Umbraco before? As far as I'm aware there's nothing specific for that version hanging around.
    If not the concepts of Document Types, content, Templates, nodes etc are largely unchanged - I'd recommend you go through the tutorials on Umbraco.tv or follow this tutorial. https://our.umbraco.org/documentation/Tutorials/Creating-Basic-Site/ using the latest version first.
    If it's an existing site have they used XSLT (to check go to Developer > XSLT)? I'd imagine it's probably all in XSLT with webforms.
    If the orignal dev(s) have used XSLT these legacy docs should help. has https://our.umbraco.org/wiki/reference/xslt/45-xml-schema/xslt-examples-updated-to-new-schema/ https://our.umbraco.org/wiki/reference/umbracolibrary/
    Then if you get specific problems I'd recommend searching via Google on our.umbraco.org forum but restrict the search dates (using the advanced search tools) to around the years 4.8 was active 2011 - 2013.
    Thanks for the advice and help Steve... I'll follow the links and come up with queries if I have any... Thanks again
